What's the worst that could happen?
Old Mar 2, 2003 | 07:35 AM
bombrider's Avatar
Default What's the worst that could happen?
If i fail to adjust my valves?
thanks
Old Mar 2, 2003 | 09:34 AM
Hightower's Avatar
Intake valve clearance typically will be the first to deminish, to the point of once the clearance is all gone, the valve will not be completely closing, suit blowing back into the carb. If an exhaust valve isn't sealing, you be blowing fire heat into the headpipes. And of course - power loss with both.
Old Mar 2, 2003 | 10:15 AM
bombrider's Avatar
Could it lead serius damege?
Old Mar 2, 2003 | 10:23 AM
Wannaride's Avatar
If you neglect it for long enough, I would think that bending valves, doing internal damage to the engine would result.
Old Mar 2, 2003 | 10:50 AM
Hightower's Avatar
Valve Adjustment
Old Mar 2, 2003 | 10:52 AM
Wannaride's Avatar
Hey Hightower,
I would love your opinion on my last post "02 Baja seems Dead", you seem to have good knowledge of the 650
Thanks
Old Mar 2, 2003 | 04:03 PM
bombrider's Avatar
Hey thanks guys, but another ?, how do i know when i need to adjust it?
thanks
Old Mar 2, 2003 | 04:25 PM
Hightower's Avatar
Checking Current Clearances, part C at the link above. Its easy to check the clearance, only disassembly is the removal of the head cover. If they're okay, you're cool, if they're not in spec you must adjust.
Old Mar 3, 2003 | 04:09 AM
bombrider's Avatar
Ok great, thanks
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
antiguogrumete
Sep 5, 2015 03:41 AM
