Need Stock Carb
Old Mar 3, 2003 | 11:34 PM
Oldmanracing's Avatar
Default Need Stock Carb
Does anyone have a stock carb that is damaged and unuseable?
I want to do some machining and will probably end up destroying the carb to get necessary information.
Thanks
Old Mar 4, 2003 | 12:19 AM
MudStud's Avatar
I have a busted stock carb.. The side cracked on it when I tried to remove the top screws to remove the needle. I dont have all the parts to it, people have needs them.. what parts or part do you want. I will see what I can do..
Old Mar 4, 2003 | 12:37 AM
I am going to step bore the spigot end of the carb.(End towards motor)
There isn't alot of material and I do not know if there is any fuel circuitry lines
beneath the surface. This is a experiment in increasing total cfm flow and maintaining
high velocity, so as not to disturb vacuum signal across the venturia.
Old Mar 4, 2003 | 12:54 AM
MudStud's Avatar
Ok, do you JUST want the body of the carb then?
I have a friend that wants the internals.. Slide, Needle etc.. There is no airfule screw any more and I have taken apart the float bowel for people that needed parts....
If that all you want I can send you that part. It will have the cover on the needle housing but no slide and needle. Below the float bowl should not matter then. if you want JUST the housing for drilling then just let me know, $15 bucks for everything including shipping.
PM me if you want any further info.
Old Mar 4, 2003 | 12:02 PM
Fourwheelphreek's Avatar
i just switched to a 45 so i have a complete take off
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
