Ideal replacement tire for Wolverine?
Old Apr 19, 2000 | 08:43 AM
Runnintaco's Avatar
Hey guys, what have you been replacing your stock 23" tires with on your Wolverine's? Mine are getting close, and I like the Goodyear Mudrunners because I hear they run good on dirt/gravel as well as good in mud too. Only thing is the smallest they have is 25x8x12 for the front and 25x10x12 for the rear. Will this slow me down? My quad has a Dynojet kit, Pro-Flo, and FMF exhaust...and i love how fast it is now....any suggestions?
Old Apr 19, 2000 | 09:30 AM
Bruce's Avatar
It certainly will slow you down. You might gain more top speed but say goodby to your torque. Your Wolverine can turn those tires but slowly and without much throttle response. I put blackwaters on mine 25x8x10 on front and 25x10x12 on the rear. I had them mounter on douglas .190 aluminum rims to save weight. I have the dynojet kit, K@N and supertrapp on mine. I forget the brand but I think they make the 489A/T tires in the stock sizes. Next time I need tires, I'm going with those. Good Luck!
Bruce
2000 Banshee
99 400EX
99 wolverine
Old Apr 19, 2000 | 09:34 AM
hunterjody's Avatar
If you love that bottom end pep that you have with the 23 then I would stick with that. I have the 25 and I would only recommend them if you want more ground clearance and want to play in the mud a little more often. You won't be alone if you go to a 25. I have seen a lot of Wolv owners on the Forum running 25 and are fairly satisfied, but the ground clearance and mud playing is generally why you would go this route. Also keep in mind that that lost bottom end will equal a little more on the top end. With the pep ups you have on your Wolv you should be able to turn those tires fairly well.
HunterJody
95 Wolverine
Old Apr 19, 2000 | 12:26 PM
FoxRunner's Avatar
I have been doing some "future" searching for new replacements. My tires are pretty good right now but I was looking into some new ones. I found some pretty appealing ones at ITP's home page. I think they were called Trail Wolf's or something? They are basically the same size as stock but a little more aggressive. I thought they looked pretty good for trail riding. Like I said with these you wont lose your pep on the bottom either. Might wanna check around some.
'99 Wolverine SuperTrapp pipe, Jetting, UNI filter, Skidplate, UFO handguards
'00 Warrior Skidplate + Bumper
Old Apr 19, 2000 | 02:28 PM
Tim1's Avatar
Split the differance and try 24"tires or 25" backs with 24"or 23"fronts of other band tires.Mud sharks make a 23"and24" size with a good tread.
Old Apr 19, 2000 | 04:58 PM
MDP49's Avatar
I don't think you can mix tire height sizes on the Wolverine because of gear ratios???
Old Apr 19, 2000 | 05:38 PM
Tim1's Avatar
I thought there was a reason you never here people mixing the front back tire size but did not Know why.I would then just try 24" all around if power loss is a concern.
Reactant
Mar 30, 2022 02:08 AM
JackTheKing
Jul 14, 2015 09:09 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
coolguy420
Jul 9, 2015 09:54 PM
jettman
Jul 6, 2015 12:16 PM
