Adding a cooling fan
Old Jan 10, 2000 | 04:33 PM
bigmanMH's Avatar
I have a 1984 200es threewheeler and i would like to add a cooling fan on it. Does anyone or dealer have an accesory like this. Or does anyone have any ideas.
Old Jan 10, 2000 | 06:35 PM
RangerSX's Avatar
Why would you want to do that? a 200cc air cooled 4 stroke will have no problems with overheating. and i have never heard of an accessory such as that.
RangerSX 1987 Honda 250X(completely stock)
Old Jan 10, 2000 | 06:46 PM
bigmanMH's Avatar
It does have a problem with overheating. I ride very slow in a crick were there is sand and i pull my motor hard up hills and never get much speed. I have already had to rebuild my motor from overheating once.
Old Jan 10, 2000 | 07:50 PM
JRM's Avatar
JRM
Yeah, I lost a upper rod berring and wrist pin on my 84' 200ES too. But I was pulling 2 traillers doubble up a 20% hill for 3 miles @ 10MPH floored in 3rd low range they were filled with firewood and hunting supplys for my cabin.
Joe
Old Jan 10, 2000 | 11:41 PM
scotster750's Avatar
When i had a 300 2X4 the amnual said that an aux. fan could be purchased from honda for extreme hot weather use maybe you could call honda and see what the price is.I could possibly be rigged to you bike.Also you may want to look into an oil cooler,and i would use as cold a heat range plug i could.Good luck.
scott
Old Jan 11, 2000 | 12:04 AM
bigmanMH's Avatar
I run what it is suppost two a NGK 7es or 7 something. What would you reccamend running.
WIll running a cooler plug decrese performance and how do you know how cold you can go.
Old Jan 14, 2000 | 07:59 AM
Brooster's Avatar
Check with your dealer I got a fan off of a salvaged bike very reasonable once for a 300.
I would also check my plug to see if it's running to lean which would also make it run hotter.
Old Jan 14, 2000 | 09:17 AM
Bill.Ciliberti's Avatar
Bigman,just a thought.I like the idea of adding an aftermarket oil cooler?I see quit a few of them on some quads.They are recommended by manufactures for extreme conditions.Best of Luck====BILL
Old Jan 14, 2000 | 10:57 AM
Eric Zeh's Avatar
I like Bill's idea about the oil cooler. If you don’t want to do that, check with your local cycle salvage yard. You should be able to pick up a cooling fan from any L/C street/dirt bike and adapt it for your application. When you set it up, it probably would be most effective if pointed directly at the top of the head. This most likely will not be possible but get it as close as you can.
[This message has been edited by Eric Zeh (edited 01-14-2000).]
Old Jan 14, 2000 | 04:03 PM
bigmanMH's Avatar
Thanks guys, I am going to try to call the honda shop about the fan.
Also i was wondering how they make the fans waterprof. YOu now where the shaft comes out of the motor and onto the fan blads i don't see anyway to make that waterproof, just an idea.
