Stroker?
Old Apr 19, 2000 | 11:55 PM
WhiteWarrior's Avatar
Anyone know where I can get the stuff to turn my Warrior into a stroker? Or even a Big Bore kit Biggest ive seen is 270cc's.
Old Apr 21, 2000 | 12:27 AM
b(250rman)'s Avatar
simple find a broken kodiak take the cylinder crank and warrior motor have the cases machined to fit the cylinder install the crank U may have to shave a little of the cases put a bigger sleeve in the kodiak cylinder put a grizzly piston in her and install a hotter cam and roost on actaully I don't know if any of that will work sounds possible though
Old Apr 21, 2000 | 08:04 PM
Heapster's Avatar
From your post, sounds like you've been huffing some exhaust fumes.......270cc? You thinking of a blaster?
I've got a 400cc Warrior, bored .080" and stroked 5.6 mm on the crank. Powroll did the crank work, and I did all tear-down and assembly. Porting, .430 lift cam, oil-cooler, 10.25:1 piston.....I did it all to my Wicked Warrior with no regrets.
For full details check it out at:
http://homepages.ihug.co.nz/~crainic/Powroll_grunt.htm
Dave
Old Apr 23, 2000 | 08:49 PM
lastwarrior's Avatar
check out team Alba the do a hell of a hop up for the warrior(dirtwheels DEC 99)up to 387cc THEY ARE CLAMING FROM 18 HP TO 30 HP + OR -
YZBlaster250
Nov 15, 2001 11:36 AM
mentalmojave
Nov 3, 2001 11:02 PM
gaff
Oct 23, 2001 05:35 AM
BANSHEE4EVER
Dunes and Dune Machines
Dec 20, 2000 08:56 AM
Zorro
Dec 11, 2000 08:56 PM
