Anybody put 20's on the back of their Scrambler
Old Apr 20, 2000 | 04:37 PM
KevinM's Avatar
Has anybody replaced the 22's on the back of their Scrambler with a set of 20's. If so, did acceleration improve any and what are your thoughts on the loss of ground clearance?
Old Apr 20, 2000 | 11:15 PM
quad_man's Avatar
I run 20" Holeshots on the back of my Scrambler when I'm not mudding. Mine is a 500, so keep that in mind.
The main thing I noticed is the corners are better, slightly lower, and gets good sidebite. There is a little more wheelspin off the start but not much, because there is also more traction, so it evens out. If you don't usually go over 45mph, I reccamend them. If you go faster than that, either get the 22" or get 20" and go up one on the front sprocket.
With my 20's, the acceleration might be a little better but not much that I can feel, the PVT just gears up higher sooner. The main place I see the benefit is lower height for corning. You can really appreciate it coming out of the corners, it seems to hook up faster and not have as much of a 'hesitation'.
Above 45mph, it takes it's time getting up to speed. With 22" tires I get the 55mph pretty easy, and then climb to 60 where the speedo stops. With the 20" I get to 45mph pretty fast, and slowly climb up to 55mph, I haven't got any faster than that yet. I would re-gear but I also switch the 22" frequently.
I found I was actualy faster on the trails around here with 22" mud tires, even though the 20" Holeshots got better traction and handling. The 500 likes the taller tires better. I am not sure about the 400. I have heard the 400 does better with smaller tires when it's hopped up.
Old Apr 21, 2000 | 03:08 PM
KevinM's Avatar
Thanks Adam, that's what I wanted to know.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
