Raptor GYT-R Clutch Problem?
Old Mar 12, 2003 | 04:30 PM
RaptorSP500's Avatar
Default Raptor GYT-R Clutch Problem?
I just put the gytr clutch in my 01 raptor. It worked fine for about 10 min then I could only shift into reverse,1st,or netrual. With the engine off i can shift through all the gears fine, once its started it stays in first and I here a knocking/ tapping sound. I jacked the quad up off the ground and with the engine running in netrual, with the cluch lever out the wheels don't move, when i pull the clutch lever half way in the tires start to spin under power, when i pull the lever all the way in the tires stop. What do you think is wrong? I downloaded the manual and followed it to install the clutch, i made sure everything was lined up where it was supossed to be.
Old Mar 12, 2003 | 04:42 PM
BigBlack's Avatar
Just a guess make sure the reverse ****/cable/lever is not stuck.
After my Raptor had set for a while I was having a very similar problem. I worked the Reverse **** back and forth a few times and it went to working again.
Old Mar 12, 2003 | 04:52 PM
I checked the reverse lever, it works fine. I can shift through all the gears with no problem when the engine is off.
Old Mar 12, 2003 | 04:55 PM
BigBlack's Avatar
I do not have a clue then. Let me know what you find when you find it.
HEY my 100th Post.
Old Mar 12, 2003 | 08:37 PM
wshrdskin's Avatar
When you installed the preasure plate, did you line up the marks on the presure plate and the clutch boss?
Old Mar 12, 2003 | 09:25 PM
Turbo33's Avatar
I would start over with the assembly and make sure you do it by the book. Remember the springs are tightened in inch pounds. It sounds to me like you are assembled wrong.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
coolguy420
Jul 10, 2015 01:17 AM
Sjrpp
Jul 5, 2015 09:04 PM
yambam13
Jul 4, 2015 01:49 PM
