creeping scrambler...HELP!!!
Old Mar 15, 2003 | 06:28 PM
BigBadScrambler's Avatar
Default creeping scrambler...HELP!!!
Ok, today it is finally 60degrees outside and the snow is melting. I was able to take the scram out for the first time since I piped, jetted, and clutched it. Well, I took it out before but couldnt get any traction[img]i/expressions/face-icon-small-wink.gif[/img] Let me tell you, this thing will bring the front end up at the touch of the throttle!!![img]i/expressions/face-icon-small-smile.gif[/img] Thanks to HPD's go fast goodies. The problem is that when it is idleing and i put it in forward or reverse, it slow creeps forward or reverse. Do i need to add or remove a shim from the secondary clutch???? Does the dealer have shims that I can buy?? Any help is appreciated
Old Mar 15, 2003 | 06:52 PM
Alpine2's Avatar
Did you change the belt when you clutched your quad ? if so it is just your belt give it a few hours and it will stop. If not you may have to add a shim but your clutch kit should have came with one.
Old Mar 15, 2003 | 07:48 PM
Yeah, I put on a brand new sp700 belt. Thats normal then?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 15, 2003 | 08:53 PM
ftwflh's Avatar
Lower the idle and ride it until the belt breaks in.If it dont loosen up may check te buttons and the bushings in the primary.
bvandass
Oct 8, 2015 09:13 AM
crazyoldfart
Jun 16, 2004 06:41 AM
RancherS01
May 31, 2004 01:25 AM
NovaKaw650
May 2, 2004 09:29 AM
HAMMERINHANK
Jun 7, 2003 10:45 AM
