400EX Switch for starting it in gear????
Old Mar 15, 2003 | 11:34 PM
Quad999's Avatar
Default 400EX Switch for starting it in gear????
I'm getrting a parking brake block off kit for my 400EX. On the stock clutch lever and perch there is a switch on it, so when you pull the clutch in you can start it in gear. How does this wook with a new clutch perch and lever that I'm getting with the parking brake block off kit? Will I still be able to start it in gear? Thanks for your help.
Old Mar 16, 2003 | 07:24 PM
Quad999's Avatar
anyone know anything about this?
Old Mar 16, 2003 | 07:27 PM
moto93's Avatar
Just cut the wires off the switch and connect them together. It will try to start whenever you hit the start button so be careful!
Old Mar 16, 2003 | 09:22 PM
Quad999's Avatar
What do you mean be careful. How will it act if I was to start it in gear.
Old Mar 17, 2003 | 11:03 AM
moto93's Avatar
Just what I said, it's going to try to start whenever you hit the button; clutch in or out and in gear or not. I wouldn't want you running into something/someone on accident.
Old Mar 18, 2003 | 01:53 AM
ORANGE400exRACER's Avatar
Just like MOTO93 said, "Make sure you connect those two wires together because if you don't, you'll have fun ONLY being able to start your quad in neutral. Just finding neutral can be a pain in the A_s-s.
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
BEEFKING69
Jun 17, 2015 12:38 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
