Warn A2000 Winch solenoid extremely hot
Old Mar 16, 2003 | 02:22 PM
MickMouse's Avatar
Default Warn A2000 Winch solenoid extremely hot
Hey all,
Has anyone with a Warn A2000 winch using the included solenoid notice if the solenoid is extremely hot to the touch. I just installed my winch and noticed that it was very warm with the engine running. And after flipping the actuator switch just 3 times so I could spool out the cable far enough to get the hook on I checked the solenoid and it felt like it was on fire. The winch seems to be working fine, however, I haven't been able to pull the cable out in freespool mode yet.
Is it normal for the solenoid to run so hot? I have it mounted in the storage box of my Eiger and I'm afraid it could melt the plastic. I think I'll disconnect it until I can get some answers.
Thanks,
Mick
Old Mar 17, 2003 | 08:41 PM
TheRedRhino's Avatar
I too have a hot solenoid. I mounted it in my storage box under my seat on a 2003 450 Kodiak. I'll ask my dealer tommorrow and see what the mechanic says.
Mac
Old Mar 17, 2003 | 09:30 PM
Kawi650's Avatar
I hooked up a switch to mine so it's on only when I need it.
Old Mar 19, 2003 | 10:18 PM
MickMouse's Avatar
Warn is sending me a new solenoid. I post back after I install it.
Old Mar 21, 2003 | 10:25 AM
action450s's Avatar
Warn had a recall on thier solenoids, they had a problem with them engaging at any time (even when bike is stored) and catching fire. happened here to the local police department!!!
Old Mar 21, 2003 | 04:04 PM
Steelhead650's Avatar
Hadf the same thing happen to me , mechanic said they always run hot. They are wired directly to the battery. I installed a simple on/off switch, and just use that when I need it. I went to get something from under the seat, Didn't even use the winch all day, and almost burned the back of my hand. Think what would have happened to the Brewski's. HeHe
Old Mar 21, 2003 | 07:04 PM
stubblejumper's Avatar
How do you tell if your solenoid is one that is being recalled?
Old Mar 22, 2003 | 10:11 PM
wisconsinrider's Avatar
For recall info go to warns web site there listed there
I checked mine out about a month ago.
www.warn something like that i forget.
2003 sportsman 2000lb old stlye warn
2003 kodiak 450 2000lb new stlye warn
Old Mar 22, 2003 | 10:25 PM
MickMouse's Avatar
Well, I installed the new solenoid today. It runs just as hot.
So I think I'm going to wire a switch to it also. Should I run the switch to the battery + lead, ground lead, or the switched + lead?
Old Mar 23, 2003 | 12:37 AM
I just checked my solenoid and it didn't look anything like the recalled solenoid.It is actually postioned under the seat with the rest of my electrical system which is much better located for access and protection than my previous solenoids.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
