brake lever
Old Mar 17, 2003 | 08:08 PM
hannahj's Avatar
Default brake lever
wrecked my scrambler doing wheelies up a hile and it flipped the only thing that broke was my brake lever part where it conects to the handlebars. does this mean i have to get a hole new brake lever and all the stuff that is connected to it the lever didnt break just the part that the lever is connected to im tryin to super glue it but i dought that is going to work i might try to find a use one
Old Mar 17, 2003 | 08:13 PM
OffRder15's Avatar
Default brake lever
What exactly broke? The reservoir?
Old Mar 17, 2003 | 08:15 PM
hannahj's Avatar
Default brake lever
no its underneath the resorvior just a pecie of plastic that holds the the resorvier and the lever on the handle bars the clamp or something that you loosen to get the lever and roservier off the handle barswith
Old Mar 17, 2003 | 08:34 PM
OffRder15's Avatar
Default brake lever
Well I don't have the upgraded master cylinder so I am not familiar real familiar with it, but if it is anything that is under pressure when you are applying the brake, I would consider is unsafe to try and glue it back. Just think if it breaks when you are trying to stop suddenly...not pretty.
Old Mar 17, 2003 | 08:53 PM
NCScrambler's Avatar
Default brake lever
You should just have to replace that master cyl. clamp kit. It is only 24.99 on partsland # 7 or give your Polaris dealer the number to order. Master Cyl. Clamp Kit Hope that helps. And no I would not super glue It because Brakes are very important and you don't want them to fail.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
tysonbully
Sep 28, 2015 02:30 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
