Scrambler tranny removal
Hey guys need help. I have all the bolts out of the tranny it is loose but I cant get the front drive shaft off. I have all the bolts out to the front diff. Do you have to remove the shaft on the diff. side? And how does that pin come out? Also do you have to remove the whole swingarm. I have the one swingarm bolt out. Thanks.
Take a drift punch and knock the roll pin by the front diff.Then slide the shaft back towards the tranny.Rear section does not have pin .Once removed from front splines pull complete skaft out of the bike.You'll see where it goes under the pull start on right side.Hope this helps!!!!!!!!!!!!!!!!!
Cantbuytime
Aug 16, 2015 09:13 PM
