SPLITTING CASES
Old Mar 22, 2003 | 02:12 PM
CrAcKhEaD's Avatar
Default SPLITTING CASES
Is it hard to split the cases on a 250r? I opened it up cause i thought i had a top end problem but its the bottom end, I can hear something rubbing I think its most likey the bearings. Would this be easy enough for me to do or do I take it to some1 that knows how and has done it before?
Old Mar 22, 2003 | 08:49 PM
dzzy's Avatar
Yes and no. I think all you really need for special tools is a flywheel puller. There is a Honda case separation tool that I've used on a stubborn one but you don't need it. You might want to buy or have access to a shop manual. I'd say go for it. I've had several apart but not for a few years as another guy at work does a lot of the two strokes now. It isn't that hard. Pay attention to how the counterbalancer was timed before you take it apart. I'll try to help via this forum if I can. There's some people on here that know them really well that offer good info too. Always remember, if it just doesn't come apart, take out that last bolt you forgot.
Old Mar 22, 2003 | 10:58 PM
DaBeechMan's Avatar
If you've never done one and you dont have a manual DONT take your motor apart. Let somebody who knows that the f**k they are doing mess with it. If you buy a manual then you'll be green to go though. THe counterbalancer is easily timed. It has markings on the gears to line up so that shouldnt be a big deal
Old Mar 23, 2003 | 01:25 AM
seanl's Avatar
unless you got a wiseco crank, they have no timing mark, just make sure the counter balancer weight is at 6 o clock(aka, the bottom) when the piston is at TDC( top dead center)
Sean
Old Mar 23, 2003 | 02:24 AM
CrAcKhEaD's Avatar
Im gonna open it up on Monday, I dont know how but i have a friend that says he knows how so ill go ahead and try (never hurts to learn new things). Where can i find some main bearings and seals?
Old Mar 23, 2003 | 04:06 AM
DaBeechMan's Avatar
Since when were there timing marks on the crank itself? All a wiseco crank is is the honda oem crank halves and the wiseco hot rod crank. Honda sells the crank halves but not the rod, thats why wiseco uses the oem crank halves and their own rods.
Old Mar 23, 2003 | 07:50 AM
dzzy's Avatar
Didn't mean to start an argument on timing counterbalancers. Yes it's easy. My point was to look carefully at things BEFORE you take them apart. Try to understand how things work and take your own notes and be detailed. I have recently started using a digital camera to help remember how hoses, cables and wires are routed. Not an issue on 250r but really useful for say, the snakepit on top of a GL1500 engine. You think you'll remember how things go, but it's easy to forget! Specially if you have to wait on parts.
Old Mar 23, 2003 | 02:01 PM
CrAcKhEaD's Avatar
Does anyone know if Sparks Racing has main seals and a complete gasket kit? They have the main bearings for $25 so i wanna order those but i cant find the seals or gaskets on their web site
Old Mar 24, 2003 | 02:35 AM
trapperb1's Avatar
www.servicehonda.com
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
1ArmBandit
Sep 8, 2015 08:59 PM
