BANSHEE CRANKS
Old Apr 22, 2000 | 10:03 PM
SBISHOP's Avatar
I HAVE A 94 BANSHEE THAT HAS BEEN PORTED BY PORTED MAGIC AND BIGGER CARBS. I WOULD LIKE TO KNOW HOW MUCH IT WOULD COST TO GET A BANSHEE CRANKS REBUILD AND WELD. I CALLED RUDY AT PORT MAGIC AND HE TOTLED ME ABOUT 800$. IT THAT TO HIGH OR DOES THAT SOUND RIGHT?
Old Apr 23, 2000 | 04:29 AM
brandon's Avatar
that sounds right for a stroker crank but thats high for a stock crank. A crank rebuild should only run around 400$ Rudy may not have understood you, or just goofed.
Old Apr 24, 2000 | 04:49 PM
Backcountry's Avatar
Might I reccommend running the TZ bearing on the drive side. I've never heard of one coming loose. Louie Swan has them in stock, I believe it's called Twist-it Cranks in Oregon (area code 503 for info).
Old Apr 25, 2000 | 01:12 AM
notfastenough's Avatar
Louie's business is called Twister Cranks his Billet stroker cranks run around $1100 He can rebuild stock one's as does any shop his phone is (503)663-7711
Old Apr 26, 2000 | 02:26 PM
Veeshman's Avatar
Try givine TDR (Tony Doukas Racing) a call, they build lot's of Banshee cranks and do a great job. I got mine with Hot Rods, trued/welded, TZ end bearings, new center bearings, rebuildable center web, all for $500. Or you could go with a stroker.
Old Apr 26, 2000 | 03:53 PM
brandon's Avatar
I used to recommend TD, but we have sent back 4 cranks that have spun the main bearings. I usually recommend having crank works do it now. I have been on mine for over 1 year, drag racing and burning alcohol, and mine is like new. For around 300$ more you could get it stroked, but you have have a head cut for it, and your ports have to be raised to compensate for the longer stroke.
Old Apr 27, 2000 | 06:21 PM
Veeshman's Avatar
When you say spun the mains, I assume you mean you spun the main bearing in the case? How did this happen and what did Tony have to say about it? Just curious, I have had no problems with mine, and it looked "brand new" when I got it also. Not sure what you meant on that one. Later.
eric
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
