How do you lighten a Lakota?
Old Apr 23, 2000 | 01:35 PM
Lakota's Avatar
Does anybody know what to do to lighten a Lakota? I did all of the performanence modifications that you can do without losing reliability-- Now I want to know how I can lighten it, if possible. Thank you.
Old Apr 23, 2000 | 03:15 PM
KawasakiKid's Avatar
One easy way is to find lighter tires. Majority of tires (i.e. spider trax) are extremely heavy. I do believe the tire alone without rim is 22lbs.
Unless you lose some considerable amount of weight, there isn't anything else you can do. Trying to reduce frame weight only leads to poor structural integrity (bend the hell out of everything easy).
Switching to aluminum parts is a good idea but again not nearly as strong as steel. Plus expensive.
If it feels like your quad is too slow or boggy, try changing it's gear ratio or carb jetting.
Mean is Green!
'87 Mojave
'87 Tecate
'00 DS650 [bigger is better]
Old Apr 23, 2000 | 04:12 PM
86Honda200SX's Avatar
You could take the two lights off the front and maybe get some of that racing plastic.I think its the same as the Mojave so since its the same it should work.Get some aluminum handlebars and DG Alloy rear grab bars.Also get a aluminum DG front bumper and get some Douglas aluminum wheels.
1986 Suzuki 230 Quadsport.
Old Apr 23, 2000 | 06:33 PM
vlucdog's Avatar
removing front and rear racks saves ten lbs.. removed front bumper and lights saved 3 lbs..my lakota has douglas rims front and rear (both .190s)front pros and alltracks both stock sizes, did not save any weight. looks cool though. for new lights i used some from auto zone (pilots)mounted to the black plastic just in front of the handle bars
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
Sandman75
Apr 27, 2000 05:54 PM
cstark
Oct 15, 1999 01:45 PM
