Help Wobble/Play in Wheel
Old Mar 27, 2003 | 04:24 PM
db's Avatar
db
Default Help Wobble/Play in Wheel
2001 Honda Foreman ES
At a standstill, the right front wheel has wobble in it. I took the wheel and brake drum off and the axle has about 1/2 inch movement left to right and up and down. Any advice would be greatly appreciated. Thanks.
Old Mar 27, 2003 | 04:26 PM
CrAcKhEaD's Avatar
wheel bearing
Old Mar 27, 2003 | 05:05 PM
db's Avatar
db
Thanks for the response. Can you help me further by explaining what I do next. At this point, I am looking at the brakes. Your help is much appreciated. Thanks. Step by step is what I need.
Old Mar 28, 2003 | 02:07 AM
CrAcKhEaD's Avatar
umm well im not really sure on how to replace it cause ive never done it b4 but i think u have to remove the hub, take the whole brake assembly off first then remove the hub and from there i have no clue, is urs 4x4? i could just look at mine but i have a 250r so its a whole lot different.
Old Mar 30, 2003 | 01:39 AM
TEXMud's Avatar
Your bearings are bad. Honda has unsealed ones and High Lifter sells sealed ones. You will also need the outer seal from Honda regardless of which bearing you use. Your best bet is to take the hub and new bearings to a bearing shop and let them install them.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
