300 EX Wheel
Old Jan 15, 2000 | 12:58 AM
BVan's Avatar
After searching for the slow leak in the front tire of my 94 EX, I discovered the tire was not the culprit....air is leaking from the small 1/16" holes drilled in the bead area of the rim. There are two sets of holes directly across from each other on the rim. I suppose the holes are to let moisture escape? My question, what would cause the air to leak from these holes? Could the rolled bead of the wheel be broken on the inside of the rim? Any ideas or remedies short of purchasing a new wheel?
Old Jan 15, 2000 | 03:06 PM
Y2K300EX's Avatar
Try to cover them up with something. J.B. Weld or someting like that. For a temporary fix try using duct tape.
Y2K300EX
'00 Honda 300EX
Old Jan 17, 2000 | 02:37 PM
brucer's Avatar
If air's coming out those 2 little holes, then you simply have a bead leak. Try some slime, fix-a-flat, the brake fluid trick someone else posted in another area, or whatever your favorite method is of fixing leaking beads.
-BruceR
'99 400EX
'95 300EX
'98 TRX90
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
