89 250r clutch update kit.
Old Mar 29, 2003 | 01:40 PM
theHulkamaniac's Avatar
Default 89 250r clutch update kit.
Dose anyone know if the 89 clutch update has a part number. Of the list of parts needed.
Also dose anyone have a comet??? cosmetic? Top end gasket set, high compression! I got one a few years ago I am going to try it, but it has two base gaskets? Should I use them both?
Thanks.
Old Mar 29, 2003 | 07:21 PM
GR8T250R's Avatar
I think this is the part # for the update kit 06220-hb9-305 I think it includes pressure plate, pushrod end, bearing, and thrust washer. If you do a searchon this forum you will find alot of info on this.
Old Mar 29, 2003 | 08:53 PM
dzzy's Avatar
I was hitting myself in the forehead trying to remember about this one earlier today and think gr8t250r is right on. I also seem to remember the reason for it being that even after you made the clutch cable as short possible, you still had excessive slack in it. I also vaguely remember installing a few of those "back in the day" and as I remember, the fix worked real well.
Old Mar 31, 2003 | 03:53 PM
Hey thanks for the help, yeah I guess I should have done the search. Lazy me! From what others have said, this should cure my problems.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
