01 Rubicon how tall a tire can I put on?
Old Mar 29, 2003 | 03:19 PM
Kansas2001Rubicon's Avatar
Default 01 Rubicon how tall a tire can I put on?
How tall of a tire can I put on my Ruby without a highlifter kit, 27"?
Old Mar 29, 2003 | 05:43 PM
slab's Avatar
id say you could probably fit 27's, i fit 26's on mine with no problem.
Old Mar 29, 2003 | 07:42 PM
666akita666's Avatar
Question for you slab. Did you have any problems with the jet kit you installed? I just installed a Dynojet kit and a K&N filter, but I am having problems with the jet kit. No matter what grove I put the c-clip on, it runs rough after idle. Can you advise?
thanks
Old Mar 29, 2003 | 07:53 PM
swampdonkeykiller's Avatar
Hey slab, how do you like your gearless locker? Is it worth the money? Does it perform as well as they say it does?
Old Apr 2, 2003 | 12:34 AM
slab's Avatar
about the jet kit i had the local honda shop do it becuase i was working a lot and didnt have time. it is just a little rough when you first go but you have to do like 2 or 3 miles an hour to notice. and about the locker, yes it does like advertisied. it makes the steering just a little harder but not to much. anything over 10mph and you probably wont even notice. it was neat to see the front wheels turning together when i climbed the rutted hill close to here. when one wheel left the ground it didnt spin out, it just acted as if nothing happened. i feel it was worth the money, but opinions vary
Old Apr 2, 2003 | 12:48 AM
hilltopat's Avatar
slab, is the locker hard to install? what all has to be disconnected to install it ? going to have one on order shortly.
Old Apr 2, 2003 | 04:52 AM
JRM's Avatar
JRM
im thinking about some 26's also, but i need a tire that can perform on my Rubicon when I ride with my friends who have sport quads but I also need the tire to stand up to abuse while hunting and traveling to crazy remote spots with slate grannete biteing at the rims
Old Apr 2, 2003 | 08:32 AM
slab's Avatar
the locker isnt real hard to install. if you want to view the instructions go to http://www.highlifter.com/installpdf...s-Locker-2.pdf and read that, it helps because you know what to expect ahead of time and there isnt as many surprises. the most aggravating part about the locker installation was keeping it together while you put it in the differential and bolted it together because it has 4 springs that had to be compressed while the cap is bolted back on. be sure to have some locktite BLUE not red. red is industrial and takes special procedures to take back loose.
you have to take the lower balljoints loose on both sides and you have to take the axles loose. then you have to pull the axles out of the diff. there are 3 bolts that hold it in place and they were locktited at the factory so have a good 3/8 or 1/2 drive rachet handy.
the outlaws that i bought have rim guards made in. the rim is about a half inch below the tire and would take some effort to get a rock to the rim. these tires grab with tenacity and will get traction on about anything and have a good ride at 5mph and above. hope this helps
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
