400 EX Stalling @ idle
Old Jan 15, 2000 | 02:24 PM
flyboy327's Avatar
I am having trouble once the machine warms up when I first get going and when I stop in idle. I have a powercore IV, K&N air filter. Every thing else is stock ( the guys @ the high pro. shop said it should be fine. I think I need to go up to a 152 main jet and that should solve the problem. Think I need to go larger? I really don't want to mess with the carb too much. I will be running @ about 1,000ft above sea level. I would love any help you guys/ girls can give me.
Thanks,
Scott
Old Jan 16, 2000 | 08:08 AM
400exinfl's Avatar
Here are things I would consider if I were in your shoes.
1) Don't touch the main jet it has nothing to do with idle speed or throttle.
2) Adjust the idle screw on the card. (The big one you can turn with your fingers.)
3) Go up one or two sizes on your pilot jet and reevaluate.
4) Take the air screw to about 1 1/2 turns out. Factory is set a 2 1/2.
Old Jan 16, 2000 | 12:11 PM
eeveslage's Avatar
Wheather it's stock or modified go to at least a 40 pilot jet. It helps starting and increases bottom end noticabley, at least it did on mine stock is 38.
franklyme
Oct 21, 2016 07:18 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
