Yet another locker idea
Old Apr 8, 2003 | 06:29 PM
Olddirtybastard's Avatar
Default Yet another locker idea
The King Quad front ends have the same gear ratio as the Cat front ends 11 pinion and 34 ring teeth. Just imagine having the ability to go from 2wd to 3wd to 4wd lock just by moving your 4wd shifter lever in a little further like the old 300 Cats. If the axles will slide in to the assembly is the big question.
Old Apr 8, 2003 | 09:11 PM
maximus's Avatar
yea man that would be nice how much would one of them set you back do you think.
Old Apr 8, 2003 | 10:17 PM
CatKrazy's Avatar
if it is the same ratio yes i believe it will. you need to call and ask someone to put a gage on the end of the spindle of the king quad and tell them to count the teeth. then take that measurment and number of teeth and call AC dealer and ask the the same thing. if they match up as far as housing width and everything else.then yes it will work.if not you will have to go to a king quad axels and front diff,very costly
Old Apr 9, 2003 | 09:57 AM
I found out that the axles are different. New axles would have to be built using the KQ inner CV and the Cat outer. Then it would work. If someone had an old KQ for parts they could do it.
Old Apr 9, 2003 | 01:56 PM
Raffica's Avatar
I am diggin' this!!! What year King Quads are we looking at for the correct parts?
Old Apr 9, 2003 | 03:05 PM
All King Quads built had the same front diff. Someone was selling a front KQ diff on Ebay last week.
fordfaithful21
Dec 7, 2015 05:52 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
