Transmission fluid??
Old Apr 14, 2003 | 06:32 PM
suds's Avatar
Default Transmission fluid??
I am going to change the fluid in my hubs on my scrambler 4x4. I was told that synthetic type f ATF fluid works better than the polaris hub oil. The problem is I can't find synthetic type f fluid anywhere. Does the hub fluid have to be synthetic or will the non synthetic type f fluid do the trick. I was also told to put in Mobil 1 synthetic ATF but it is not type F, will this still work, or is it absolutely necessary to to have type f. what would happen if I did not run type f fluid in my hubs.
Thanx for the info
Old Apr 14, 2003 | 06:41 PM
PolarisPower500's Avatar
I use any type F fluid, I have SuperTech right now. Its not real important in those hubs, oil is oil.
Old Apr 14, 2003 | 07:01 PM
hAzArD's Avatar
whats wrong with the regular polaris hub oil, whats the flaws of it, whats better bout the ATF fluid, i guess i figured its best to use the polaris stuff but im open to hear everyones opinions!
Haz!
Old Apr 14, 2003 | 07:06 PM
NCScrambler's Avatar
I have used the Polaris hub oil for 5 years now with no problems.
Old Apr 14, 2003 | 07:16 PM
hAzArD's Avatar
yea same here i just use the polaris hub fluid, and i was also wondering, how often should i change my hub fluid, or what is kinda a rule of thumb i guess?
Haz!
Old Apr 14, 2003 | 08:39 PM
BigBadScrambler's Avatar
I would love to use the polaris hub fluid, but my nearest dealer is 50 miles away. That is a long drive for a little bottle of oil. I only make the trip for parts, oil, and trans fluid. You should change it every 100 hours, or when you change your oil. I use the Mobil 1 Synthetic ATF. I could not find the type F Mobil 1. I have had a to take apart my hubs a lot lately, (new seals twice, cv joints, cv boots) so the 1 quart bottle of trans fluid will last awhile. The mobil 1 is apparove for fords, but is not a type F. I was told that a non type F cant be mixed with a type F. That was the only reason that you had to run type F because it is compatable with the polaris hub fluid that is left in the hub. Someone correct me if Im wrong. But, when I had my hub apart, I cleaned EVERYTHING with brake cleaner so that none of the old oil was left. So it should be fine to run the Mobil 1 syn.
Old Apr 15, 2003 | 12:21 AM
suds's Avatar
Thanx for the info
Old Apr 15, 2003 | 12:24 AM
BigD500ho's Avatar
I believe, but I could be wrong, type "F" just means rated for Ford
Old Apr 15, 2003 | 12:40 AM
The type "F" is for Ford. But the regular Mobil 1 syntetic is approved for certain Fords, however is is not a type "F"
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
