Just wanted to say thanks
Old Apr 19, 2003 | 07:51 PM
GoldProspector's Avatar
Default Just wanted to say thanks
Had one of those great 200 dollar service jobs done ,now i got a boat anchor.It runs good up to about 30 then it starts to spit ,sputter ,cough, gag. It still has the (condensation )problem as the dealer puts it.CHanged the oil 5 times and it still gets milky. I was reading some of the post last night and came across the snorkle needs to be through the ruber flap,post .So i take a look IT AINT THROUGH it ,it is somewhere under it.Fixed that ,checked the plugs ,black as coal,cleaned them.Looked at the belt,yep it has one and that is the limit as to what i know how to do .But it now runs 65 instead of spitting and gagging to get to 43.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 19, 2003 | 07:54 PM
nyroc's Avatar
Good job! Glad you fixed it. I did that same thing too once upon a time.
Old Apr 19, 2003 | 08:09 PM
Nyroc i went to your fix it page .It was a real big help,but i am not real sure as to where the black spring and red spring everyone is talking about go and didnt feel like pressing my luck on tring to tighten the belt up.With everything off i can almost touch the 2 sides of the belt together ,the clutch is spooled all the way out so the belt is touching the shaft . I know the clutch draws in some at start up and further in to take off and so on .The belt looked to be in good shape ,only have 458 miles on it. There is some free play at the clutch . THat is where you take the shims out right? Am i on the right track with this thinking
Old Apr 19, 2003 | 09:14 PM
nyroc's Avatar
Look at the tech tips titled Driven and Drive Spring Faq should help you clear things up. You will get less pulley wear and longer belt life if you look into it and do the belt adjustment.
Nondem
Feb 22, 2020 12:20 PM
nachop
Feb 14, 2018 06:57 PM
Ean
Aug 28, 2015 09:39 AM
NatePerz
Jul 27, 2015 03:27 AM
toonces
Jul 11, 2015 12:01 PM
