scrambler 400
Old Apr 20, 2003 | 05:05 AM
brandons's Avatar
Default scrambler 400
i was riding for like a hr or so then my fourwheeler just shut down an wouldnt go anywheres i tried to start it an the coil just spun an it wasnt catching but it wasnt making the sound that it should when a starter is blown so i have no idea what is wrong with it so if any1 can help me please do thanks
Old Apr 20, 2003 | 12:10 PM
modquad's Avatar
Brandons, what year is the machine, how many hours/miles est. If you have the stock throttle, there's an ETC inside that kills the motor if throttle cable tension is lost. First thing though, make sure you didn't bump the killswitch on the LH handlebar. Do you have more than 1/16" of freeplay in the throttle. If so, you can tighten that up with the adjuster nut. It's under a rubber protective boot, on the throttle lever end where it enters the throttle control housing. Also have you tried pull starting the machine. Sounds like your starter bendix needs lubrication, or replacement. Do you regularily drain any moisture out from the recoil housing. There's a drainplug for that, there's also one on the starter. Get yourself a maintenance manual, it'll help you find all these components, as well as keep your machine running in great condition. Saves you time and money too. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 20, 2003 | 02:36 PM
brandons's Avatar
well i tried pull starting it an there is no compression inside of the engine either, i looked at my throttle cable an eveythring looks fine an there is no play in the throttle at all,
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
