Honda 1984 TRX200
Old Jan 18, 2000 | 09:12 PM
JustinKing's Avatar
I need help
I have honda 200 and whenever I shut the engine off, I can hear something spinning and I don't know what it is so if anyone can help I would really appreciate it
Thanks
Old Jan 19, 2000 | 02:16 PM
Texridr's Avatar
Sounds like it could be your clutch. Does it occur with the transmission in neutral, or in gear, or both? Does your bike lose engine braking when going downhill when the engine speed is at idle? If so, that's another indication of a clutch problem. I would guess that its the centrifugal clutch (as opposed to the change clutch) and its drum is worn or grooved. Unless someone with more experience responds, it seems a removal of the side cover and an inspection of the clutches is in order. Good luck.
[This message has been edited by Texridr (edited 01-19-2000).]
Old Jan 19, 2000 | 06:07 PM
200xtra's Avatar
i used to have a lemon trx125 and i replaced the clutch twice and it used to do that.
Old Jan 20, 2000 | 09:38 PM
coryatver's Avatar
I have a 86 trx200sx and I have the same problem. I don't know what it is ether. Also the axle bolts are striped out.
Old Jan 21, 2000 | 10:24 PM
bigmanMH's Avatar
Just wondering but if the clutch basket is worn does that mean that it has to be replaced if it is working properly.
Old Jan 22, 2000 | 02:28 PM
JustinKing's Avatar
coryatver does that only happen when you are in neutral or in gear or both
mine only happens when i am in neutral
Old Jan 22, 2000 | 10:49 PM
coryatver's Avatar
It happens almost every time i shut it off.
--Coryatver
www.geocities.com/cory_14
I have pics of mine on my page
Old Jan 22, 2000 | 10:54 PM
exlax250x's Avatar
if your basket is worn file the teeth down so the plates will slide it makes a big difference
Old Jan 23, 2000 | 09:56 PM
Adam Zuroski's Avatar
My friend has an '86 200SX and his does the same thing. I used to have an '84 200S and it had practically the same motor. I'm pretty sure the manual said it was what I think they called and oil rotor that was spinning. You were actually supposed to take that part of the case off and clean in when ever you change the oil, I never did it, so I wouldn't know if that would help it or not. This might be the problem, not sure though.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
