400EX OWNERS, I NEED YOUR HELP!!!!!!!!!!!!!
Old Apr 21, 2003 | 11:58 PM
rustyshackleford's Avatar
Default my fourwheeler wont run
we recently rebuilt the top end on my 400ex and it wont start. we have tried everything, we sent the stator to Ricky Stator but it is fine so he did not rewind it. We took it to a certified honda mechanic and he inspected the carb completely and found nothing wrong. It has to be the carb though because it is getting spark with both my stator and the one out of my dad's 99' 400ex. What do you guys think.
Old Apr 22, 2003 | 01:12 AM
CrAcKhEaD's Avatar
Default 400EX OWNERS, I NEED YOUR HELP!!!!!!!!!!!!!
hmmm all a bike needs to start is gas, fuel, and compression. so im gonna assume its not gettin compression...did u put the cam chain back on? did u put the rings on? i dunno im stuck
Old Apr 22, 2003 | 11:23 PM
the mechanic we took it to did a leak down test and it was one of the 5 or 6 that he has tested that holds over 100 psi.
my dad thinks that it is getting to much fuel and is flooding out all the time. this is because i put a bigger pilot jet in it when it was still stock, but it has alot more vacuum pressure and is sucking in way to much fuel. does this sound logical
Old Apr 22, 2003 | 11:30 PM
ORANGE400exRACER's Avatar
Are you sure that you checked your timing. It sounds to me that your timing is off. Even if you think you put the timming chain back on right, it's still possible that your timing could be off. It happen to me!
Old Apr 22, 2003 | 11:39 PM
the mechanic checked that to. it is timed perfect is what he said
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 22, 2003 | 11:44 PM
How long did your carb sit during your rebuilt. Sometimes when you rebuilt a motor and a carb sits the fuel in the carb can turn into varnish and cause your floats to get suck and it can flood your engine. Why don't you try the carb off your dads 99 ex?
Old Apr 23, 2003 | 12:38 AM
We did.. It acts like the thing is firing on every 4th revolution.. Pull starting it doesn't work. It just pops and lurches. I have never seen anything like this before... I'm sure it's something simple but it's driving me crazy.... The top end has been off twice, the original carb has been opened up twice also.. The stator, cdi module and the coil have been switched...It still won't run...... HELP!!!!!
Old Apr 23, 2003 | 12:55 AM
Dude, it sounds like your timing is off. It could be off a tooth or so. Checking your timing is easy. Go to exriders.com. There they have easy guides to check your timing, adjusting valves, and troubleshooting.
Ahtatu
Sep 28, 2015 12:14 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
