2002 kodiak reverse rev limiter
Old Apr 23, 2003 | 11:44 PM
sledneck4banger's Avatar
Default 2002 kodiak reverse rev limiter
Does any one know how to bypass the reverse rev limiter on the 2002 400 kodiak????
Old Apr 24, 2003 | 10:19 AM
sxr6's Avatar
Someone answer this, I'm tired of this ????
Old Apr 24, 2003 | 10:32 PM
Well I just got off the phone with a buddy of mine he`s got a 03 grizzly and he told me how he did it on his.
step 1 Locate the wiring harness behind the fuel pecot(****)
step 2 Locate the white wire with the green stripe
step 3 strip it back with out cutting it and sodder a wire to it and silicone it up and tape
step 4 run your wire to a 2 post on/off switch
step 5 run ground wire to the other post on the switch
step 6 mount your switch
Ill let ya know if it works on the kodiak but it should I am told
Old Apr 25, 2003 | 02:43 AM
Camo01Kodiak's Avatar
I found a reverse rev limiter bypass wiring harness on ebay Reverse Rev Limiter Bypass For the Grizzly and the Kodiak.
Old Apr 25, 2003 | 09:28 PM
It did not work but i just bought one off ebay thanks to camo01kodiak.
Old Apr 20, 2005 | 05:42 PM
STOCKWELLBELL's Avatar
I attempted to access the link to the ebay site to order the rev limiter override. The link no longer worked. Do you have a new link to this ebay site? Do you know if anyone makes a bypass for a 2005 Kodiak?
Thanks
Old Apr 20, 2005 | 06:54 PM
hondabuster's Avatar
No need to buy a kit, look over these pictures...the kodiak and grizzly use the same color wire. Green with white stripe.
grizzhopper
Old Apr 23, 2005 | 01:28 PM
katman's Avatar
i need that on my 02.......is it pricey ?
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
atvcollector
Sep 8, 2015 05:11 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
