Buying a used Fourtrax
Old Apr 24, 2003 | 11:51 AM
Cal's Avatar
Cal
Default Buying a used Fourtrax
I am in the market for a used ATV and found a Honda 2002 Fourtrax 250cc. It has 804 hours on it and I was hoping someone could tell me what the lifespan of these motors were? Thanks
Old Apr 24, 2003 | 01:27 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Are you talking about a Recon.
If this is the case that is a lot of hours for a one year old quad.[img]i/expressions/face-icon-small-shocked.gif[/img]
The tires have to be shot!!
It sure hasn't been sitting much and I would ask for the oil change and airfilter cleaning records.
How much do they want for it?
Chet
Old Apr 24, 2003 | 02:05 PM
Coyotechaser's Avatar
Did they tell you that there was that many hours on it or is there something installed on it to keep track?
Old Apr 24, 2003 | 02:09 PM
Cal's Avatar
Cal
This is a canadian model. 2002 Fourtrax 250 4X4. And I think I could grab it for just around $900 US which is why I'm considering it. The specs are:
Engine
229cc air-cooled, single cylinder, four stroke
Bore and Stroke
68.5mm X 62.2mm
Compression Ratio
9.2:1
Valve Train
OHV, 2-valve
Carburetion
Single, 22mm
Transmission
5 speed + reverse, electric shift transmission
Final Drive
Rear shaft
Front Suspension
Independent double-wishbone, 130mm travel
Rear Suspension
Swingarm with hydraulic shock, 125mm travel
Front Brakes
Sealed, dual hydraulic drums
Rear Brake
Sealed, mechanical drum
Front Tire
22 X 7 - 11
Rear Tire
22 X 10 - 9
Wheelbase
1131mm (44.5 in.)
Seat Height
777mm (30.6 in.)
Dry Weight
188.0 kg (414 lb.)
Fuel Capacity
9.1 litres (2.0 Imp. gal.)
Old Apr 24, 2003 | 02:15 PM
RIP Dear Friend
Coyotechaser,
I keep a log book on mine with the aprox hours + or - 15 minutes useage per day. I do this so I have an idea for oil change and other items.
Your right unless they have an hour meter on the quad I doubt if they have kept records though because most don't.
Chet
Old Apr 24, 2003 | 02:18 PM
RIP Dear Friend
Looks like a Recon here in the states and its not a 4x4 and you will be able to see this by looking at the front end.
$900 dollars US. I might chance it at that price
Chet
Old Apr 24, 2003 | 02:37 PM
I was trying to figure out how many hours my Recon had on it. The first year I didn't put much on it because I still had the Warrior. I've been riding ALOT this year right through winter. I don't keep records for the Recon but I wish I did. I do for my vehicles and boat. I was averaging around 5 or 6 hours a week. ( Around 8 miles a day) I change the oil every couple months.
Cal- That price seems a little too good to be true. Are you sure it is a 4x4 or do you mean 2x4? It sounds like a Recon, but I know from the Honda UK site that sometimes they do rename the atv's for other countries. Did it have a speedo on it? I think the UK models come with a speedo. It does seem like the hours are high but if it is in good condition it sounds like a good price. (Comparing to US pricing) Just look it over really good.
Old Apr 24, 2003 | 02:39 PM
Raptoryfm660R,
How many atv's do you have? Just wondering.
Old Apr 24, 2003 | 02:47 PM
RIP Dear Friend
three
I would start up a log book right now, better late than never. I use one of those small memo books that are 3x5in.
Chet
Old Apr 24, 2003 | 03:00 PM
Cal's Avatar
Cal
He states that it is a 4X4 but after your comments I did some checking and found that model doesn't come in a 4X4, only 2X4. The guy is lying. Thanks for all the help
