Lost Bottom End With HMF Duals
Old Apr 28, 2003 | 08:10 AM
NYVForce's Avatar
Default Lost Bottom End With HMF Duals
I have the airbox mod and 160, 165 jetting the plugs are tan, a twin air filter and HMF duals it is much faster at the top end but it seems to have lost a little at the bottom. I was wondering if it was the pipe or maybe my belt should be tighter, what are the specs on the V-Force belt for deflection. I hopefully will get the lowend back when I get my EPI clutch kit but it's still on backorder. Thanx
Old Apr 28, 2003 | 08:34 AM
POLARISFREAK's Avatar
I'd say the pipe has changed the power band and a clutch kit with more engagement should bring around the low end.
Old Apr 28, 2003 | 10:39 AM
mtecate4g's Avatar
Did you shim the needles like suggested by HMF? That may be your problem.
Old Apr 28, 2003 | 02:14 PM
NYVForce's Avatar
Yes the needles are shimmed, it seems to slightly backfire when I let off of the gas when I'm really on it.
Old Apr 28, 2003 | 02:30 PM
STAKK's Avatar
sound's like the air screw's aren't rich enough if it backfire's when you let off the gas......
Old Apr 28, 2003 | 02:42 PM
mtecate4g's Avatar
Stakk's right. The air screws are adjusted wrong if its back firing. That could also be the causer of the loss of lowend throttle response.
Old Apr 28, 2003 | 02:43 PM
NYVForce's Avatar
Where are the air screws, do you think I'm running to rich.
Old Apr 28, 2003 | 02:48 PM
mtecate4g's Avatar
backfire is normally caused by a lean air screw. The airscrews are located on the bottom of the carbs by the float bowls. Their a gold colored flat screw in a recessed hole. Turn clockwise to lean it out and counterclockwise to richen. Turn them about a 1/4 turn at a time. try it then if not right another 1/4 turn til you get it right.
Old Apr 28, 2003 | 03:08 PM
NYVForce's Avatar
The plugs look tan on the electode and blackish at the threads, do you think I need to richen the air screws. Can I do that without taking the carbs out and can I see them when the carbs are in place. Thanx for the help.
Old Apr 29, 2003 | 08:45 AM
NYVForce's Avatar
Help do you think it's the air screws I need to beat my old DS650, I need all the help I can get or do you think my jetting is on and I need to do something with the clutching. Although I don't think the slight backfiring when I get off the gas when I'm on it is normal is it, I mean it did'nt do that with the stock exhaust and jetting. Help guys. Thanx
