Lost Bottom End With HMF Duals
Old Apr 29, 2003 | 09:13 AM
mtecate4g's Avatar
Default Lost Bottom End With HMF Duals
You can richen the air screws with out taking anything apart. You just look under the airbox on the right hand side of the bike you'll be able to see the float bowls and the air screws. More than likely you'll have to richen them but you may have to play with them a bit to get them adjusted right.
Old Apr 29, 2003 | 01:10 PM
STAKK's Avatar
The best way to know if they are set right is to let the bike warm up and let it idle in neutral, then start turning one of them counterclockwise(rich) until it idle's down (rough) then simply stop and turn the other way(clockwise) 1/2 turn and you're done, do the other carb the same way........
Old Apr 29, 2003 | 01:45 PM
NYVForce's Avatar
where are the air screws on the V-Force will I know them when I see them, are they the same on both carbs. Thanx
Old Apr 29, 2003 | 02:08 PM
STAKK's Avatar
Right in the middle of both float bowel's there are two flat head screw's in a recessed hole there are no other's in a recessed hole, these are the air/pilot screw's.....
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
Sep 30, 2015 01:37 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
