missing problem
Old Apr 29, 2003 | 10:39 AM
650rider's Avatar
Default missing problem
I have a 2001 ds. Lately it has started to miss and start cutting out around 3600-4000 rpm. If I turn my headlights on high it stops. I have changed the battery, checked and cleaned the carb., and made shure that the battery is charging. I dont know what else to do. I asked the dealer and he doesn't have a clue either. Can anyone help??
Old Apr 29, 2003 | 02:08 PM
joshiepoo's Avatar
what you're discribing sounds like electrical of some sort- like in the ignition somewhere, it might be just a loose connection, check those i guess, hey u mentioned that it stops? the motor stops? or the missing stops? but it still sounds like ignition somewhere, so i'd start with electrical first.. lates josh...
Old Apr 29, 2003 | 02:30 PM
bigR's Avatar
I had the exact same problem a couple years ago. Turn on the lights always fixed it...
It turned out the problem was a bad ground. Check the ground connections. Clean and scuff it with something like a wire brush..
skinnyr6
Aug 25, 2023 02:18 AM
Firefighter400
Oct 8, 2022 06:38 PM
Captjay
Jul 23, 2015 12:33 PM
blpersinger
Jul 15, 2015 09:56 PM
steveo612
Jul 11, 2015 08:35 AM
