Lt80 needs some help
Old Apr 29, 2003 | 08:14 PM
Dougersq's Avatar
Default Lt80 needs some help
I am working on a friends 1999 LT80 and I am stumped. It will start up fine and idle ok but falls on its face when you try to give it gas.(I have a 1991 and my friend has a 2000 and both are very snapy right as you tap the gas.) This one will hardly move and when it gets some speed it seems to have good power. I have swaped the carbs with his other LT80 and it ran the same. I pulled off the piston and it all looked fine. We put in a piston since we had it all apart. Still nothing changed. I have swaped the coils and still no change.I have raised the back end off the ground and reved up the motor and it is still not as snapy as my other quads. My friend bought this quad and did not know that it had anything wrong with it, so we do not have any history of the quad. Any help would be great.
Old Apr 29, 2003 | 10:07 PM
Mercerman's Avatar
Any chance theres still a restrictor in the exhaust where it mounts to the head?
Old Apr 30, 2003 | 12:07 AM
LT80's Avatar
LT80 Expert
Pipe restriction maybe.if not,,,What about the clutch's??? I think the brass on the front clutch broke / roller problem (gut feeling). [img]i/expressions/face-icon-small-smile.gif[/img]
Please keep us informed.
Old Apr 30, 2003 | 06:55 PM
Dougersq's Avatar
Yes I have checked the pipe and the restrictor had been removed it was one of the things we had hoped was wrong. As for the front rollers I did have the side case off and cleaned all rollers and put gease on them, cleaned all the dirt out of the rear clutch. I did not notice any thing wrong with the brass on the front drive face,but I was not looking for anything to be bad up in that area. I will check it out in the next few days and let you know what I find. Thanks for the help. Keep sending me anything you can to help. Ideas
Old Apr 30, 2003 | 07:46 PM
LT80's Avatar
LT80 Expert
OK,If you didnt notice anything wrong,then it's fine.
Bad reed? Guess thats my next guess [img]i/expressions/face-icon-small-confused.gif[/img]
Old May 8, 2003 | 07:49 PM
Dougersq's Avatar
Hi I have not had the time to do more work on the quad yet , this time of year I work 2 full time jobs and I get 0 done at home. I will try the reeds and let you know if that was it. I have had them out and looked them over but I do not know what would make them bad. once again any other help would be great thanks Doug
Old May 8, 2003 | 08:04 PM
Rad-R's Avatar
Old May 8, 2003 | 11:03 PM
LT80's Avatar
LT80 Expert
Huh? Wha?
LOL! [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 15, 2003 | 02:50 AM
predator530's Avatar
yeah i would check the reeds and also the spark plug and end gap
Old Jun 16, 2003 | 05:47 PM
pain's Avatar
i have got the same problem with mine tried all the above and still the same.is there anymore suggests outthere?could it possibly be out to do with timing?
