look what i did
Old May 4, 2003 | 01:07 PM
brad650's Avatar
Default look what i did
i was torq'in the clutch bolts down just now to 7.5 ft lbs, all of them were going down fine and one of then fu*kin snapped off inside so what the hell do i do now??? theres a busted off bolt in my clutch! [img]i/expressions/face-icon-small-sad.gif[/img] HELP
Old May 4, 2003 | 02:08 PM
brad650's Avatar
anyone?
Old May 4, 2003 | 02:28 PM
YZF's Avatar
YZF
you have to drill it with a small drill and easy out it.
Old May 4, 2003 | 02:32 PM
brad650's Avatar
allright
Old May 4, 2003 | 02:52 PM
BIGBAJA's Avatar
I would use an inch pound torque wrench on those bolts. (89 inch pounds) A foot pound torque wrench is not accurate at such low numbers. The broken piece of bolt should be loose and come out easy. Depending in where and how the bolt broke you might be able to stick a small screwdriver in the hole and back the broken piece out. It is worth a try before you get the drill out.
Old May 4, 2003 | 03:29 PM
jetjock16's Avatar
brad, i broke two of mine off also, they dont take much in the way of tight'en them.. anyway i do have a tap kit and got it out and everything and was about to drill it when the bolt just turned right out with the drill bit, so i took a little screwdriver to the other broke one and was able to work it out without ever having to drill them, my point, is they are very loose in there and easy to turn so get a small screwdriver and you should be able to twist the broke bolt out.
jetjock16
Old May 4, 2003 | 03:54 PM
brad650's Avatar
allright, ill do that! thanks sooo much guys
Old May 4, 2003 | 03:56 PM
ThePunisher's Avatar
You have to use an INCH LBS> Torque Wrench!!!!! Not a Foot Lbs. one. 89 Inch Lbs. is all it takes,
Old May 4, 2003 | 04:09 PM
brad650's Avatar
yep
