Sand tires/wheels for front..Do I really need 1" offset?
Old May 5, 2003 | 06:42 PM
RaptorCam's Avatar
Default Sand tires/wheels for front..Do I really need 1" offset?
Getting ready to order some Mohawk's for the front of my Raptor and cannot decide if I should get the stock offset or plus 1" each side. I put Elka's on a while back and they completely changed the handling characteristics of the Raptor. I am leaning toward the stock offset, simply because of the added stress put on the tie-rods, etc., with the additional width. The a-arms and swingarm are stock.
What does everyone think...Stock or +1? Pro's, con's, and suggestions welcome!! Thanks
Old May 5, 2003 | 06:51 PM
warrior620's Avatar
As for the stress on the tie-rods go, I dont think 1'' wider will hurt them. The 1'' offset will give you quite a bit more stability up front b/c it will be a total of 2'' wider in the front (wider is better). Do you still have stock axle?? If you do just flip the rear wheels.
Old May 5, 2003 | 06:56 PM
RaptorCam's Avatar
Stock axle but offset wheels with paddles. Right now, the front and rear are very near the same width.
Old May 5, 2003 | 07:36 PM
wshrdskin's Avatar
I've been running the 1" offset front rims for probably close to 1 year now. I ride pretty hard and have had no problems. Very noticable improvment in handling.
Old May 5, 2003 | 07:54 PM
sixsixT's Avatar
1" offset.
Old May 6, 2003 | 12:49 PM
RaptorCam's Avatar
So, It looks like there is no good reason NOT to get the offset?
Old May 6, 2003 | 01:06 PM
racereadyraptor's Avatar
I don't know if I would go with the Mohawks...They're a ton hevier than a set of dune trackers!Your front end will feel kind of bulkey. I had them and sold them to buy some trackers.
Old May 6, 2003 | 01:13 PM
RaptorCam's Avatar
How much heavier do you think they are? I rode with a set of dunetrackers and didn't really like how the jerked around. They seemed to grab almost too much.
Old May 6, 2003 | 01:23 PM
I love the way they hook up in the sand....It's just what you like I guess.As far as weight goes...I couldn't say exactly.Go to you local shop and put a tracker in one hand and a mohawk in the other,you will see what I mean. Every pound counts on the way up the hill!!![img]i/expressions/face-icon-small-wink.gif[/img]
Old May 6, 2003 | 09:09 PM
sixsixT's Avatar
Are you sure it was mohawks and not shark fins you were comparing. My mohawks are pretty light.
badgerboy1
Sep 26, 2017 06:11 PM
black_thunder
Sep 20, 2015 10:21 PM
Jason Campbell
Sep 7, 2015 02:25 PM
rawbdiggity
Sep 7, 2015 12:05 PM
