Sport Quads Discussions on sport quads.
Blaster 240 Bore help?????
Old May 14, 2003 | 01:42 AM
BlaSteRidr's Avatar
Default Blaster 240 Bore help?????
Hey, recently i have been thinking about moding my Blaster engine, it is completly stock and after looking at mods I have been stumbling into some confusion, can you guys clear these up for me?
The 240 bore from Vito's for $250, do you have to send them money and your engine to get it installed or can you do that yourself, or do you have to go to a machine shop in your area? if so how much will it cost? and is it worth it or would it be worth getting a 240 bore from vitos that is a bolt on for about $500? I know I can install that. Also what are the most benificial mods to do to a blaster to get the most power out of it for the least amount of money, excluding a pipe.
Old May 14, 2003 | 11:09 PM
YFZRacer's Avatar
you would send it to them i would think.
also the 240 kit for 250bucks won't actually increase your performance by that much it will just give you more potential once you add other mods such as bigger carbs, pipes, and porting. so yah i would look into a pipe then porting then bigger carbs and you could get a 240 boring 2. check out ct racing 2 they have some awesome kits 2.
Old May 15, 2003 | 12:02 AM
BlaSteRidr's Avatar
Yea I saw that CT Racing Big Bore kit that comes with all the pistons and jets and even pipe for $1000 that sounded like a lot to me but then i figured that most people put more than that in there quad for less, I will really consider that kit, what do you think about the vito 240 bolt on?
Old May 15, 2003 | 12:45 AM
SpinCycle's Avatar
Get the CT kit!! It will make 40hp or so and will be a freeking WILD ride! It uses a 250R reed cage and it's a whole new casting for the cylinder. 40hp in a Blaster would kick butt...
Old May 15, 2003 | 08:32 AM
gaff's Avatar
I've done the 240 kits in blaster as well as many other kits. With out a pipe, carb, read cage, clamp on, and ect. you won't feel the real benefit of the kit. Expect $1000 to $1500 investmint to get what your looking for.
Now it's common knowledge to flip the wheels on a blster to spread you out a lil more. It's also common knowledge to remove the air box lid, drop the c-clip on the needle one position and bump the main up a couple sizes.
But my best advice to you would be buy the toomey pipe, filter and jet kit for about $345 to start with. Then get some tires and suspention. Then worry about the engine work. With the toomey kit alone it realy wakes it up a bunch. Also have enough power to go up a tooth on the front sprocket.
Another note about a 240 kit with all the goodies, it really needs a extended swing arm and some chassis mods.
Just start with the toomey kit and let the fun begin
Old May 16, 2003 | 12:05 AM
BlaSteRidr's Avatar
Hey thanx for the help that vleared a lot up for me, but it also cloaded some things up for me to =) Like the "common knowledge", I understand the whells and removing the airboc lid but im a little confused with the jettings stuff, can you please clear that up a little for me. thank you
Old May 16, 2003 | 02:44 AM
YFZRacer's Avatar
the jetting is what controls how much gas is being taken up. when you increase the power and flow of an engine you need more gas to compensate. Therefore you jet richer or bigger to allow more gas to flow. The other variable is the how high you are from sea level. stock is like 230 or something similar, with a toomey kit they suggest a 310 and that is what i use. hope that helps a bit
peace
Old May 27, 2003 | 04:41 PM
ZBlaster's Avatar
i HIGHLY recomend the Vitos kit. it gives plenty of options for a price that wont break the bank. i would recomend going with a 34mm carb port and polish it and add a pipe silencer and jet kit.
Old May 27, 2003 | 10:32 PM
2000blasterbeater's Avatar
you'd kill yourself on a stock suspened and stock width blaster with a 240 kit..
lol i wrecked mine more than once because it was tippy..and that was just with the mods listed on it below )
Old May 29, 2003 | 01:12 AM
hondaracer305's Avatar
I have read about vitos perf. and you have to send them your topend and your money
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
nastyblaster100
Sep 13, 2015 01:19 PM
