Flat tires ?
Old Jun 15, 2003 | 11:47 PM
jwoodsman's Avatar
Default Flat tires ?
Hi every one .
I've been visiting this site for some time looking for incite on witch type if ATV to buy , after months of reading the good and the bad I decided to perches an Arctic cat 400 4x4 auto new 2003 model .so far I'm impressed ,My first 8 miles on it are just from giving me kids rides around a 1/2 acre yard . I took it out behind the house last night and this morning I had two flat tires ,what's the best way to repair ATV fix a flat or patch ?
Any input will be appreciated , Thanks jwoodsman
Old Jun 16, 2003 | 12:16 AM
CatsMeow's Avatar
plug it if you have a hole. if you dont see a hole check your beads and valve stems.
Old Jun 16, 2003 | 01:27 AM
BigBadScrambler's Avatar
Whatever you do, don't use Fix-a-flat. It will eventually destroy your rims and be a big ole mess and pain in the **** to clean off the rim. I put Slime in my tires and it works great. Seals puntures up to 1/4". Put it in before you get a flat. Plus, it is biodegradeable and washes right off.
Old Jun 16, 2003 | 11:27 PM
ElectricShift's Avatar
My tires have atleast 3 plugs in each one, I am too cheap to buy tires.How did you manage to get 2 flats? nails?
Old Jun 16, 2003 | 11:42 PM
jwoodsman's Avatar
I'm not sure ,I have to pass over one barbed wire part of an old fence ,that's where everybody rides through
no barbs left on the wire, just wire .
Thanks guy's I did try the atv fix a flat with no luck, I drove around for two hours with the holes still leaking ,
I ended up using the real sticky rope plugs ,they worked like a charm ,Now I just have to get the fix a flat out .
I was kind of hesitant on using plugs because the quad was only 5 days old . Just like the saying goes they don't last forever.
[img]i/expressions/face-icon-small-smile.gif[/img]
2quiker
Mar 22, 2022 08:36 PM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
caveeagle
Sep 19, 2015 01:20 PM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
