need help bad
Old Jun 17, 2003 | 02:01 AM
500man's Avatar
Default need help bad
going riding in a mouth or so and my wheel feels loose it drives fine but i dont know y its so lose my lug nuts are tight is it the wheel bearing or a cv or something like that is it anything to be worried about?
thanks Derek
Old Jun 17, 2003 | 11:03 AM
Olddirtybastard's Avatar
500man- Try to tighten the nut in the center of the wheel. If the center nut and your lug nuts are tight, it is most likley a bad wheel bearing.
Old Jun 17, 2003 | 11:12 AM
bbertram's Avatar
Don't drive it until its fixed too.
Old Jun 17, 2003 | 01:09 PM
500man's Avatar
the center bolt is tight.
so it cant be the cv then? that all the other guys r always breaking
how munch are bearings
thanks
Old Jun 17, 2003 | 04:23 PM
The only way a broken axle can make your wheel loose is if it broke inside the steering knuckle. If this is the case your wheel would be held on only by the brake caliper until it falls off completely.
A loose tie rod end bolt will also make your tire feel loose. Jack it up and see where the slack is. Bearings are around $35 each.
Old Jun 17, 2003 | 04:51 PM
bbertram's Avatar
Yah jack it up and shift the tire around, not turn it but move it horizontally, if you know what I mean. If it wobbles its most likely the bearing.
Old Jun 17, 2003 | 11:55 PM
500man's Avatar
whats up with ur pics
Old Jun 18, 2003 | 12:08 AM
voodoo's Avatar
Opps my bad, i fixed it hehe, was messing with subdomains...
