help jetting a 2001 500auto
Old Jun 30, 2003 | 06:50 PM
acfan's Avatar
Default help jetting a 2001 500auto
I have a 500 Auto that shows to be runnig rich (plug is black).The bike has a K&N filter installed.The factory main jet was a 145, and ran rich then so I got a jet kit (K&N/Dynojet kit) and installed per kit inst a DJ132 with needle set to #4 and fuel mix set to 3 turns still running rich. The kit has 124,126,128,130,132,134,136 jets.To lean out do I install larger or smaller # jet ? or should i change the needle ? Just ordered a supertrapp exhaust, What should i use with the new exhaust ? any help ?
Old Jun 30, 2003 | 08:56 PM
Bigcat's Avatar
acfan
to run it more lean, go to a smaller jet ex. 132 to 130
or go to #3 on the needle ex #1 is the leanest and #6 is the richest, #1 is the top grove.
I put a Dynojet kit in my 2002 500i 4x4 the kit suggested a 132 jet, it was great, but it would go over 35 miles per hour, so I changed 132 for 134 jet. Man what a differance, tons of power...... Dynojet says every atv will be different, no two will be the same.
I hope this helps....Oh did you check the float height (17mm.....0.7in.)
Old Jul 1, 2003 | 05:04 PM
acfan's Avatar
If you change to the K&N filter this ads more air so why is the jet size smaller than the factory 145 not bigger
Old Jul 1, 2003 | 06:17 PM
Bigcat's Avatar
The Dynojet Kit Jets do not match the Keihin carb jets, and the Dynojet Jet Needle is also a different size.
Now with the K&N air filter does have a little more air flow the the stock fliter but not that much.
When you get your supertrapp exhaust the engine will breath alot better and you will have to use a bigger jet ( I looked it up) DJ136.
I hope this helps
Old Jul 1, 2003 | 08:23 PM
acfan's Avatar
Thanks, the numbers just don't add up. The 145 has a larger hole (mesured with drill bit) than the DJ132 ? Wish the supertrapp was here so a can start tunning ordered 26" mudLites also !!!!!!!
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
