CV Boot
Old Jul 28, 2003 | 10:35 PM
BYBob's Avatar
Default CV Boot
thanks foir all the reply's. I howere am not 15. I do as much possible to watch what I am riding over but sometimes you cannot avoid things. I did however purchase the whole axle assy. Not by choice however and much to my dismay. I respect my equipment as much as possible. I will have to try those kevlar boots and it need the axle place if this happens again.
Old Jul 29, 2003 | 09:51 AM
bbertram's Avatar
Default CV Boot
You can also buy boot protectors. They are a plastic or metal shield that bolts onto your a-arms. They block sticks and such, I don't know if the 300 comes with them stock, if not buy some aftermarket ones that should help alot.
Old Jul 29, 2003 | 11:15 AM
sxr6's Avatar
Default CV Boot
You can also use automotive boots on the 4 wh, they're a lot thicker rubber & tougher! I know the boot of a Geo metro or GM sprint is same size as 300 Cats use but not sure on the bigger bikes?
Old Jul 31, 2003 | 12:02 AM
Gup's Avatar
Gup
Default CV Boot
Check out norrecind.com. Their boots stretch over the joint so you don't have to remove it from the axle. The boots wear good too.
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
cornermike
Sep 10, 2015 08:30 AM
