what is the Top Speed of AC 400 4X4
Ok, mine is an 03 400 4X4 manual... and they did not come with low range reverse (in Canada anyway, don't know about US models). As far as I know the automatics are in high range reverse as well ( after I found out the facts the hard way I went and asked our only dealership up here). You should find out when you're stuck in the mud or somewhere, a lot of times mine won't even be able to turn a wheel 'cause it's geared too high. The 02 models had high and low range rev. but they changed things for the 03 models... . Well, I went and got a jet kit, K&N filter... to get a little more bottom end power, it helped a bit.
Bottom line is that this 400 AC is still a lot of ATV for the money (I use ATV's for 16 years mainly for work), easy to work (service) on and I will get another AC (this time for more play) as soon as I have more cash.
yeah.....the reverse is pretty low on myn......and it stays that way unless you press and HOLD a little yellow button that is next to the electric start button....then it takes off, it'll spin the wheels in reverse when I hold that thing down......not much, but it does
