Tire Alignment--500 Auto
Old Jun 2, 2000 | 09:59 AM
CatLance's Avatar
I tried to use the string method on my 500 auto & found it difficult because the rear is so much narrower than the front. Does anyone know a better way? I ended up using a tape measure to the inside of the rims but it is still difficult to get an exact measurement because of the frame & drivetrain being in the way. Do you guys set them up straight & true or toed out a little? If toed out, how much? Mine came from the dealer with the left front toed out almost 3/4 of an inch, is that normal Q\A or do you think something happened to it along the way? Sorry for the long post and thanks for any help you guys can give. Lance
Old Jun 2, 2000 | 11:03 AM
pete/ny's Avatar
Cat- I have a Polaris but this will work on yours to. I bought 1 piece of 1/2x1/2 aluminum angle 6 ft long. I cut it into 2 3 ft lengthes. Duct tape one each of them to the sidewalls of each front tire at a 3 and 9 oclock position (level all the way across) Put your handlebars straight as you can and then hold them in position with a tie down strap at each end and fasten each to a rear rack to hold them from moving when you adjust each tie rod. Measure the distance from each piece of angle both sides, front and rear. Adjust both tie rods to give your front tires the exact same distence from each piece of alngle, both front and rear. Then adjust each side to give you the amount of toe in or out required. On my Polaris I run 1/4 inch toe out. The book calls for 1/8 but found that it handles better on trails with alittle more toe out.You will have to split the difference on the measurements, say your machine calls for 1/4 inch toe out- it means you have to have an 1/8 on each tire. Good luck, if you have any questions let me know and I will try to hhelp you more.
Old Jun 2, 2000 | 11:24 AM
CatLance's Avatar
Pete, Thanks for the tips, I especially like the straps to hold the bars in place, that was the most frustrating part with them moving back & forth. I'll try it tonight & let you know how it goes. Where do you other Cat owners set your toe at? Lance
Old Jun 2, 2000 | 10:47 PM
sxr6's Avatar
On my Cat the tire has a mold rib around the centre that makes it easy to measure front & back, but any method will work, straight edge, I have also used a straight 1 X 2" board. About 1/4" toe out should be good.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
