2WH AND 4WH DR.
Old Jun 8, 2000 | 11:19 AM
sly's Avatar
sly
I HAVE HAD SOME TROUBLE PUTTING MY Y2K 500 AUTO BACK IN 2 WHEEL DR. AFTER WE GET THREW SOME AGGRESSIVE RIDING. I TRIED PUTTING IT IN NUTERAL, DRIVE,REVERSE,GIVING IT A LITTLE GAS,NOT. PULLING THE LEVER OUT, FEELS LIKE IM GONNA BRAKE IT OFF BEFORE IT WILL PULL OUT AND DISENGAGE. WHEN I DO IT WHEN WE FIRST GET ON THEM IT EASY AND SMOOTH. DO YOU THINK IT JUST NEEDS TO BE BROKEN IN LONGER (115)MILES ON IT, OR SHOULD I TAKE IT BACK TO THE DEALER.
THANKS SLY
Old Jun 8, 2000 | 12:23 PM
Tcat's Avatar
I occassionally have this problem with mine (300 miles), usually after stopping abrubtly then trying to disengage. I just ease it forward 10-15 feet, and it usually disengages without a problem.(Used to work on my old 4x4 pickup too) I think the problem is that it doesn't want to disengage when there is a torque acting on the differential. If that doesn't help, I would have the dealer check it out.
Old Jun 9, 2000 | 03:01 PM
rhamann's Avatar
I've had a similar problem with engaging/disengaging the 4wd on the 500 auto. I haven't found anything that works consistently. Next time it happens, I'll have to try Tcat's suggestion.
Old Jun 10, 2000 | 08:33 PM
vtCatamount's Avatar
I have almost 400 miles on mine. Same thing--IF--I try to go from 2WD to 4WD or vise versa when at a stop. I almost always switch when just barely rolling. It hasn't hurt anything and works much easier. I learned it during my first week of riding and have been doing it ever since. Give it a try.
Old Jun 13, 2000 | 01:30 PM
sly's Avatar
sly
I just tried it. And it worked pretty good. And it is actually quite smooth. Thanks for the tip it worked pretty well. Thats good forum.
Thanks SLY
Old Jun 13, 2000 | 05:25 PM
dustytippins's Avatar
my unchles 300 4/4 with titan 589 on it if you lock it in foreward you had to unlock it in reverce
Old Jun 14, 2000 | 08:48 PM
JakeGun's Avatar
I had the same problem with my one of my cats. When I first got it, I had to fight it to get it to shift. Now its pull up and back up over and over to get it to release. On the other one... I have never had this problem.
Old Jun 14, 2000 | 09:23 PM
stevie's Avatar
JAkegun if your names a joke i dont find it very funny but if it isnt i gope everything is better over there
