Replacing tires on my Artic cat Question
Old Nov 29, 2003 | 11:08 AM
Bearcat2's Avatar
Default Replacing tires on my Artic cat Question
Hello,
i found this site while searching for tires , so i joined and will ask the question , my 25 inch tires are wore i would like to replace them with ITP Mud Lites , my stock tires are front 25X8X12 my rear is 25X11X12 i would like to go with the Mud Lites which is front 27X10X12 and rear is 27X12X12 so will these tires fit my Artic Cat will i have any problems if i go with a 27 inch tires or should i go with a 25 inch tire . my Artic cat is a 1997 454 full time 4X4 used on the farm , running fences etc... hunting and pushing snow
Thanks for any replies
Bearcat2
Old Nov 29, 2003 | 04:46 PM
FUFIGHTER's Avatar
thats a good question i was wondering that myself, the only thing is that i want a 26 inch tire on my 2003 500 i'm not much help but i will be watching your post to see if theres anyone that can help! im also conserned weather the bead will be to big for the stock rim if i go wider 2 sizes.
Old Nov 29, 2003 | 07:46 PM
ACDVX's Avatar
There is alot of room for those tires
Old Nov 30, 2003 | 01:23 AM
Fango's Avatar
You should be able to run 27's with no Problemo. You may experience a slight power loss with the larger rubber but I don't think you will be disappointed with the added clearance and traction.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 1, 2003 | 02:06 AM
1Badcat's Avatar
I have a 2003 500 auto with 26 inch mud bugs . So far ive gone through 1 balljoint and two rear wheel bearings after 1500 miles .My dealership blames it on the tires ,it may be the rough trails i ride but this beast should take it even with 27,s. . . Other mods big gun pipe ,jet kit ,custom front and rear bumpers,homade coolent overflow tank,should of had from the factory,custom plow
Old Dec 1, 2003 | 05:20 PM
mudblaster's Avatar
the mud lites are a sweet tire but if you stay with the stock size you wont get the deep lugs.
you need to go with at least 26" tall to get the deep lugs.
and the mud lites are lighter then the itp or gators or any other tire for that matter.
so they say .
i think my next set of tires will be the mud lites.
but untill my gators go bald im sticking with them.
i love my gators.
i've put 1600 miles on them so far and they have barly worn at all.[img]i/expressions/face-icon-small-smile.gif[/img]
im very happy with my tires but i think they are a little heavy.
but the cat dont seem to mind.
Old Dec 4, 2003 | 11:58 PM
Bearcat2's Avatar
Hello,
Well i got the 27s Mud-Lites , my first thought WOW this babies are kinda big , i put them on and rode around the yard alittle , the power lost on the lowend is very low , this 454 is geared kinda low even in high range , top end it did increase the top end which i like . i will ride it some more on Friday as iam going bow hunting this weekend . i did weigh the tires before i switched them out here's the weight on stock tires and the 27s , i used a hansen scale stock front tire weigh 25lbs. front 27 inch Mud-lites weigh 39 lbs, stock rear tire weighs 30 lbs. 27 inch Mud-lites rear weigh 41 lbs. here is a photoalbum of my cat .
Thanks again for the replies
Bearcat2
http://community.webshots.com/album/103229748WuYkfD
Old Dec 6, 2003 | 02:01 AM
Diesle's Avatar
So, are they at all close to rubbing any where on your bike?
Diesle
Old Dec 6, 2003 | 10:49 AM
Bearcat2's Avatar
Hello.
Diesle
here is a picture link to my Cat . you can see the difference from stock tires to the 27 inch tires .
for a test i went through a creek with 2 ft of water , went through some really good ditches , a good size mud hole which i soaked my @ss with cold water mud/ rode down the blacktop for a mile . as far as the tires go iam Happy so far i will see how well it goes through snow when we get some ,
Ride Safe
Bearcat2
Old Dec 6, 2003 | 06:15 PM
akfireman's Avatar
bearcat2, are those stock rims that you put the 27's on, i want the same tire, but dont really want to buy new rims, I will probably get the kit though
