lights
Old Jun 20, 2000 | 10:51 PM
oaks's Avatar
I just bought a set of running lights to put on the front of my 2000 ac 400 4x4 . both the axil plug and the lights are rated at 15 amps. do you think this will be ok
Old Jun 20, 2000 | 11:35 PM
Tree Farmer's Avatar
You already mounted the lights? NOW you wonder if it's o.k.?
Just kiddin', man!
Forgedaboudid! Fear not! Give it the "smoke test!"
I assume your auxiliary outlet is properly fused; if not, you may blow your 30 amp main fuse if things go dreadfully wrong. Until that happens, don't worry! Be happy!
Tree Farmer
Old Jun 21, 2000 | 01:59 AM
Andy Bassham's Avatar
that seems awful big. I had 4 150 watt KC's on my old truck and they pulled around 12.5 amps each. Are you serious about 15 because I wouldn't think an atv battery would do much with that. I could be totally off here, but that seems rather high to me.
Old Jun 21, 2000 | 11:14 PM
JKB's Avatar
JKB
The Ac literature shows alternator output at 25 amps. If I remember correctly amps can be found by dividing voltage by watts. This would confirm what Andy mentioned about the current draw on the KC lights. That would put the bulb wattage at around 85 per bulb assumming that the 15 amp rating was for both.
Jim
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
