wiring grip heaters
Old Dec 17, 2003 | 03:52 PM
okbow68's Avatar
Default wiring grip heaters
Just got the AC grip and thumb heater kit. I havent tore into it yet, but I want them wired in so they cant be on unless the key is on. Does anybody know which wire coming out of the switch would be right for this on a 2003 400? Thanks for the help
Old Dec 17, 2003 | 08:24 PM
roscoe69's Avatar
Check the accessory plug to see if it operates from the switch, if it does wire it from there, better then screwing around with the wires to the switch. i wired mine from switch and then someone came up with the idea of running it from accessory. i wired wifes from accessory , a lot easier
Old Dec 18, 2003 | 09:12 AM
TORK's Avatar
You can also wire in from the fuse block, I believe it is the orange wire that gets current with switch on.
Old Dec 18, 2003 | 04:45 PM
okbow68's Avatar
Thanks guys
erntee61
Aug 9, 2015 02:54 PM
Stirling
Aug 9, 2015 01:49 PM
DeFox500
Jul 26, 2015 06:32 PM
mdrkcckv
Jul 22, 2015 09:10 AM
Scottma518
Jul 10, 2015 12:42 AM
