Roll Bars on ARTIC Cat 650
Old Jan 9, 2004 | 07:27 PM
Greywolfhound's Avatar
Default Roll Bars on Ac650
NEW At THIS!!!
Has any one tried the roll bars or cages on one of these tall machines? How top heavy are the cages. I wounder if they will fit the MRP racks? Second question: Are the warn winches equipped with limit switches? Mine will continue pulling until it damages the front of the machine,,,,not good.
ARTIC CAT 650 MRP
Warn Winch 2500
Old Jan 9, 2004 | 08:30 PM
Bendman's Avatar
Roll bars???
Old Jan 10, 2004 | 10:16 AM
Wires's Avatar
Originally posted by: Greywolfhound
Second question: Are the warn winches equipped with limit switches. Mine will continue pulling until it damages the frony of the machine,,,,not good.
Then you have a little problem. You have a winch that needs to pull between 2000 and 3000 lbs (depending on the model), so how would you want to limit that? That's what it's designed for.
Old Jan 10, 2004 | 11:27 AM
The limit switch that I was refering to is actually a stop when you retract the cable. So the cable will not pull the hook in and around the spool of the winch, thus damaging the winch mount. The dealer was telling me that someone actually damaged his mount by retracting to far.
How close is your winch mounted to your radiator, mine seems to nearly touch, maybe too close?
Artic Cat 650 MRP
Warn Winch 2500
Old Jan 10, 2004 | 11:42 AM
Originally posted by: Bendman
Roll bars???
Yes, the rool bars are made and look neat, just a question of weight (top heavy) to the extreme. You can even get a canoe mount for the top of your rig, I am not sure that I would want one.
Artic Cat 650 MRP
Warn Winch
Old Jan 10, 2004 | 12:42 PM
Wires's Avatar
Default Roll Bars on ARTIC Cat 650
I see.
I've never seen an ATV winch with a limit switch. I think they expect a little bit of responsibility from the operator.
My winch is fairly close to the rad. Seems fine though.
Old Jan 11, 2004 | 11:38 PM
manmudcat's Avatar
Yah, I had a limit switch on my 500i and also the 650 LE comes standard with one!
IT,S called your finger!!!!!!!!!!!!!!!!!!!!
Old Jan 12, 2004 | 12:37 AM
Wires's Avatar
Ha ha ha... that's a good one!
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Albertaboyy
Sep 9, 2015 09:51 AM
