Blowing headlights
Old Jan 28, 2004 | 08:39 PM
Dozzna's Avatar
Default Blowing headlights
I have had my AC 250 2x4 for about ten months and have replaced 7 headlights,1 battery,and a voltage regulater that after I waiting for six weeks the wiring connections were not even the same.Now its been in the shop two weeks.All the Arctic Cat has to say is call your dealer!Did I mention the closest dealer is about 70 miles.Any one else blowing headlights
Old Jan 28, 2004 | 09:58 PM
Bear4570's Avatar
Had to have both headlights and wiring harnesses to them replaced on my 2001 AC 250 about 3 months ago. No problem since, but then again I only have about 35 hours on it since then and haven't use the lights much. I used to work on outboard motors which use the same style of charging systems and my experience, for what it is worth, would be to change out the stator and regulator at the same time. I've seen a bad regulator screw the stator which in turn screws the new regulator or visa versa. The manufactures tech guys have even recommended it for persistant problem children.
Old Jan 29, 2004 | 07:36 PM
Dozzna's Avatar
Thanks its about time someone has a clue.My lights are on all the time. low and high there is no off.I am going to fax over the information that you gave me to the dealer so hopefully it won't be third week.Thanks again for the info.
Old Jan 29, 2004 | 07:45 PM
Bear4570's Avatar
What year is your 250? Mine, a 2001 AC250 allows you turn the lights on and off with the second position on the ignition switch. Bear
Old Jan 29, 2004 | 07:54 PM
Dozzna's Avatar
Mine is a 2002 and only has low and high and they are on all the time.How about everyone else?
Old Jan 29, 2004 | 07:56 PM
Dozzna's Avatar
I just now realize what you mean about the ignition.Thank If I hhad it I could try it.
Old Feb 1, 2004 | 01:41 AM
ecorman1's Avatar
Way to go Bear... You be the man.
Chuck
Old Feb 1, 2004 | 03:22 AM
mudcatsick250's Avatar
sounds like somethins wrong with your fuse block or you have a short to ground, never had a problem with the lights on my cat
Old Mar 18, 2004 | 11:08 PM
crown's Avatar
In response to your headlite probelm.i own a 2001 Arctic Cat 250 4x4.one headlite was always dim.
the nearest thing to an Arctic Cat dealer where i reside is a Suzuki dealer.their tech advised that
Arctic cat put Halogen lites in this particuler brand of Arctic cat(unsure of other models).
he advised the heat of these bulbs is too much for the electrical system.in fact one of my plastic
housing was melted around the bulb.he replaced them with regular bulbs.
this dealer also sells yamahas and they have the same problem.
as an aside my brother has a 2000 Arctic Cat 500 4x4.He replaced the stock lites with a set of driving
lites from canadian tire.however he has only high beam but is happy with the results.
hope this is of some assistance to you
Old Mar 18, 2004 | 11:09 PM
crown's Avatar
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
PrairieDog126
Sep 16, 2015 01:33 PM
