clicking noise
Old Jul 3, 2000 | 11:10 PM
sly's Avatar
sly
I have a y2k ac 500 auto and when going down real steep hills, I apply the brake and I experiance some wheel hop and a metal clicking sound. The cat is new so I dont think there is any cause for alarm, But what is the clicking metal sound. Also the hills are real steep.
Thanks SLY
Old Jul 4, 2000 | 12:59 PM
BEARTACKER_250's Avatar
is it comeing from the back brake.
Old Jul 4, 2000 | 03:57 PM
minehunter's Avatar
If the noise only happens while going down hill in 2 wheel drive and applying the rear brakes only, that is normal. It is caused by uneven torque loading on the limited slip cams in the front differential. If the hand brake is used,the noise should diminish. There should be no noise from the front end if you are in 4 wheel drive and you apply either the hand or foot brakes.
Old Jul 4, 2000 | 05:59 PM
vtCatamount's Avatar
Mine does it too but only when in two wheel drive, breaking, down steep hills. I attribute it to "slop" between the tranny and wheels. When it does it, look at your rear wheels, I think you will find not only wheel hop, but the wheels lock, unlock, lock, etc...
Old Jul 11, 2003 | 09:05 AM
Bob2003's Avatar
Default clicking noise
I have a 2003 500I auto it does the same clicking down hill in two wheel drive in 4 WD its ok. I also had clicking noise on rear wheel when rockink it or in reverst dealer said it was wheel bearing he replaced it all is ok.
Bob
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
