Engine Cuts Out on Artic Cat 300 2x4 (1999)
Old Aug 12, 2000 | 02:20 PM
Bearcat99's Avatar
Hello
When running at full throttle, in any gear, the engine hesitates as if its not getting gas for a second.
I've replaced the gas filter, cleaned the air filter AND drained the carb bowl to no avail!
If anyone has any ideas, some help would be appreciated!
-Bearcat99
Old Aug 12, 2000 | 03:51 PM
thud's Avatar
have you checked you vent hose? could be pinched or plugged just enough to cause a fuel feed problem at high revs... or perhaps the idle is set too hight and its flooding itself at high rpms ( mine came like that from the dealer, was set for cold weather starts and as soon as the motor warmed up it would stall itself at high rpms ) just a thought
Old Aug 12, 2000 | 04:28 PM
N1TE0WL's Avatar
My 500 was doing that exact thing also. Seems I had a good bit of mud in the muffler. Try unbolting the muffler and removing it then see if it still cuts out when running just a straight pipe. If this fixes it you might have to replace the muffler with a new one or refer to this thread on what I did to my muffler
Old Aug 13, 2000 | 06:11 PM
xplorer's Avatar
sounds to me like your just hitting the rev limit.However I could be wrong but my rev limiter stops high revs in each gear just as you described.When it maxs out its rpm it acts as if its running out of fuel until you back off just a tad then it resumes as normal right?
Old Aug 14, 2000 | 02:21 PM
Bearcat99's Avatar
Thats right explorer, but other Artic Cat ATV's I've rode have not done this..
Old Aug 14, 2000 | 04:16 PM
BadCat's Avatar
The service manual list's nine conditions:
1. Rev limiter
2. Valve springs
3. Vavle timing
4. Cam and or rocker arms
5. Spark plug gap too narrow
6. Ignition coil
7. Float level too low
8. Air filter element dirty
9. Fuel hose obstructed
Hope these help you.
Old Aug 16, 2000 | 01:44 PM
MudCrazy's Avatar
I Have a Cat 300 4x4 and it started doing the same thing after jumping of into some water. As best I could tell, the fuel metering rod had slipped out and was sitting in the carb at an angle. It ran fine till I would hit the throttle hard, then it choked out. If this is the case, then you have to take the carb out of the machine and take the bronze cover off the top. Inside is a spring that sits on top of a small plastic button that sits on top of the metering rod. If the rod is sitting at an angle, pull the spring out and flip the carb up-side down to get to the metering rod and the plastic button. Put the rod in the center hole and put the plastic button on top of the rod. Put the spring on top of the button, and put the bronze cover back on the top of the carb. If this is your problem, then this should fix it.
Old Aug 16, 2000 | 10:16 PM
BIGBADCAT's Avatar
I was having the same troubles with my 454. As I went along the problem continued and did nothing but get worse. It was also backfiring everytime you would let off the throttle at almost any speed above 20. All I did was change the spark plug. Now it is running like new.
Old Aug 19, 2000 | 10:30 AM
dustytippins's Avatar
my 300 did the same thing what it is is the jet in the carburator is to big it has a 137 in it we took mine to the dealer and they put a 132.5 in it and it never did it agin or if you buy a new air filter it wont do it until it gets dirty to fix it with out going in your carburator bbuy a k&n for a 99 suzukie king and it will fun good i had to do all that to my 300 so try that and it will run right
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
kdg723
Jul 25, 2015 01:20 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
