snow plows
Old Nov 2, 2004 | 08:21 PM
m74me's Avatar
Default snow plows
If you remember good old Pathagoreas from your math class, he would tell you that a 60" plow on a 15 degree angle would plow about 58" wide, on a 30 degree angle would plow about 52" wide or on a 45 degree angle (which I don't think you can achieve) it would plow about 42 1/2" wide.
Old Nov 3, 2004 | 08:27 PM
KansasCitySam's Avatar
Default snow plows
[img]i/expressions/face-icon-small-smile.gif[/img] Thanks for all the info, I think that I will be buying the 60" plow.
Will I be needing the chains? I have 4 - wheel drive. just one more question, does the blade have a problem with floating on top of the snow? or is there enough weight from the blade and frame to keep it down.
Old Nov 4, 2004 | 02:13 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default snow plows
We just got 14 inches of snow and I will be plowing tonight! I do have chains but have never used them. The only reason for it would be if there is all ice below the snow, then they would come in handy. The blade is pretty heavy, it won't float on top of the snow. My dad has only the 1500 Warn winch and it has a hard time holding the plow up. I have no troubles with the 2.5ci Warn. Good luck!
Old Nov 4, 2004 | 08:08 PM
mudblaster's Avatar
Default snow plows
Kansascitysam.
you were asking about why everyone was saying 60" insted of 50".
i think it has to do with how wide your quad is my 03 cat was from outside edge of the tire to other outside edge was 52". with the stock tires i think it was 50.
now if you have a 50"plow your quad will be wider then the plow.
and im not sure you want that.
i had the 60" plow on my cat with 28"gators on it and it plowed fine.
now im going to use it on my honda and i think it will be ok also.
i have the cycle country metal plow and aperantly it hooks up a little differant then the cat nylon plow
but i havent seen how the cat one hooks up so im not sure.
but mine hooks up under the running boards and has two little tabs that stick down on each side and the plow gos in between the two tabs. and on the front it just hooks to your winch and thats it.
easy to go on and off.
but the one thing i found with thouse hooks (tabs) under your running seem to take a beating in the summer time i found that out when i whent to hook up the plow to plow my horse corrall out i ended taking them off and fixing them then putting them back on.
Old Nov 5, 2004 | 03:49 PM
  #15
turbocoupe's Avatar
Default snow plows
i just got a moose setup for my 650LE i bought the 60in blade due to it swipes 52 in when angled. also its a quick disconnect with pins and the mounting plate is small under the quad the cat plow frame runs the entire lenth of the bike i didnt care to much for that but thats just a matter of opinion i guess anyhow after all said and done it cost me 370.00 bucks for everything and a couple hours of assembly
Old Nov 5, 2004 | 06:10 PM
  #16
millsd's Avatar
Default snow plows
Did you get the County plow or standard? If the county, seems like a really good deal. So far, I've only found the county setup for around $340. If you know a better place, please let me know.
Also, I think you can get a different push tube that allows higher lifting of the blade. Anyone familiar with that on the Moose or Cycle country plows?
Old Nov 5, 2004 | 06:55 PM
  #17
turbocoupe's Avatar
Default snow plows
i got the 60 in moose plow also i got the new m93 push tubes it allows you to pick the plow up higher you can try bettencourts honda im sure they will ship it to ya or give them a call 508 587-1701
shimanok2
Jan 29, 2016 07:37 PM
Irishman301
Sep 23, 2015 01:47 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
